Configure Firepower Management Center for PKI/CAC login
Eric R. Jones
Level 4
Level 4
Hello, we got our Firepower Management Center setup and working on the network. It's not in production yet so I have been applying STIGs and doing configurations. I would like to know if anyone out there has applied PKI/CAC configurations and if you did through the system > integration > identity sources menu. I was applying the various certificates as requested but needed the key for the FMC cert.
ej
0 Replies 0
