11-11-2006 06:27 AM
I have 2 traffic generators, 1 is TCP & other is UDP. I wanna use them with WRED but with assigning min,max thresholds.This configuration i want to do without CBWFQ, secondly the min,max threshold command has ip-precedence(0-7) in it.
I want to assign ip precedence to these traffic sources, but i donno how. I basically wanna test behaviour of different traffic sources using WRED.
pls guide
thanx
saif
11-11-2006 09:09 AM
I think UDP would not help out for the usage with WRED . TCP would work out .
Pls use this link for ref :
Hope this helps
regards
vanesh k
11-13-2006 12:01 AM
thnax fot the reply. I understand your point about WRED not being helpful for UDP. but my questions are still there:
1)using WRED, how do i assign traffic for diferent precedence in order to change their min,max thredsholds.
2) Is their a way to only configure WRED & change its parameters & not configuring it throughb CBWFQ.
regards.
saif
