Copy running-config from ASA via SCP stopped working
jakub-maliska
we used to download running-config from ASA firewall on remote server using command:
scp user@ASA_IP_ADDRESS:system://running-config running-config
and I'm certain it worked with some older version of ASA. Now the firewalls are updated to  9.20(2)21 and it looks like it stopped working, I'm getting error:
scp: no such file or directory
Did something change or am I doing something wrong? Can you help me?
5 Replies 5
Try use http to download run config
I think there is bug in some asa ver. Make scp not work.
It more easy if you have asdm
MHM
Thanks for the suggestion but ASDM is not enabled due to the security reasons.
check if the bug below applies. The workaround is to disable to SSH stack:
ciscoasa(config)# no ssh stack ciscossh
https://bst.cisco.com/bugsearch/bug/CSCwh93649
Actually scp copy from the firewall works. This is a Firepower 2110 firewall and the notes at the end of the bug article says that Firepower 2100 is not affected.
But due to the security reason it was requested to initiate the configuration backup from remote backup server, not from the firewall. Therefore scp from router is currently considered only as a workaround.
Anyway, thank you for the suggestion.
kewwa
scp -O
solved my problem
The flag -O = > Use the legacy SCP protocol for file transfers instead of the SFTP protocol
