[CPAR] (How-to) add AV-pair to specific LDAP groups
Carlos A. Silva
Level 3
Level 3
Is there a document or presentation that guides you (at all or as much as possible) in how to set up a Cisco Primer Access Registrar and an LDAP server so that when different users/groups that reside in the LDAP server are assigned different attributes (for example, different policy-map for BW rate-limit) when authenticated by a CPAR that checks that LDAP server for usr/pwd credentials?
Even if that document doesn't exist, a brief description on how one is supposed to set this up would be very helpful.
Thanks!
c.
0 Replies 0
