cpu loading
leungcm
Level 4
Level 4
we "sh pro cpu" and there is one record
Check heaps
We check the cisco and it will check the mem. what memory does it check? if the % is high, where do we check to? please advise. thank
Best regards
Joe Clarke
Check heaps is a process that ones once per minute to check all memory pools and free lists on the device (i.e. it looks for memory corruption). The memory it checks is processor RAM and I/O memory. So it is normal to see that process jump in its CPU usage every time it runs.
we have two routers both of them have the similar config (same hardware). but the loading is different. one is 6%, other is 32%. could you put your email address in "top netpros" so that we can send you the config for your reference. We would like to find out why second router with higher cpu loading. Thanks
Best regards
If you cannot post the information here, you should open a TAC service request, and work the problem with TAC.
