Creating Ciscoworks Groups Programatically
anthony-johnston
Community Member
The title says it all - I have about 5000+ switches and routers which I need to place into about 1200 groups. If I used the GUI it would take forever to do this so I was wondering if there was a way to do it programatically? I can use the device name to identify which group to assign it to.
akemp
Level 9
Level 9
There's only one problem, Ciscoworks doesn't support 1200 groups, a closer number to reason would be 100 groups.
With that said, you can automatically assign devices to group based on their attributes like:
IP address
Device.ManagementIpAddress range "10.[96-118].[0-255].[0-255]"
hostname
Device.DisplayName contains "bubba"
device model
Device.Model equals "2948"
what organization it belongs to
Device.DomainName endswith "bubba.org"
and so on , there are 14 fields that you can parse combine or discriminate with using Boolean operators AND OR EXCLUDE. Thee of the fields are user definable.
Hi Thanks for the reply.
I wasn't aware of the 100 group limitation which seems rather low. I was aware of the flexbility of group creation using the GUI but I thought that with the cwcli interface or something equivalent I might be able to script it
