Crypto Engine Error
EugeneZorin
Community Member
Please help !!!
What does this message mean:
CRYPTO_ENGINE: crypto_pak_coalesce: could not allocate pak.
The search has no result.
guruprasadr
Level 11
Level 11
HI, [Pls RATE if HELPS]
If you turn on crypto debug on VIP, you will see that message:
"CRYPTO_ENGINE: could not allocate pak."
This problem can occur if user running software encryption on a fast interface like FDDI.
There's no workaround for this problem.
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
