CW 2.6 on Solaris with multipathing
dmitry
hi,
I've tried to find some info on the subj. on CCO and looks like nothing is available. I need to connect a Cisco Works 2.6 server (Sun Fire 280R) to two switches in a datacenter in the failover configuration, Solaris has this multipathing function (sort of NIC teaming), so the question is if CW supports that.
David Stanford
Campus Manager will only support discovery out of one interface. You will need to set a primary external interface for LMS...and this can be done in the file gatekeeper.cfg
