cw java problem
bennyferber
I have lms 3.0.1
when I try to open the topology services I am getting error message: "could not find main class. program will exit"
What can I do to make it work?
Benny
Joe Clarke
Try clearing out your Java Web Start cache on the client. To do this, open the Java Control Panel, go to General, then click the Settings button under Temporary Internet Files, and delete the files.
If the problem persists, it may be a server error. Try launching this on a different client, and see if the problem shows up there.
