12-20-2008 08:28 AM
Hi Experts,
I have run the change hostname.pl script in bin folder as instructed by the Common Services user guide.
However, CW LMS Portal url doesn't change according to the new hostname. Is it normal or do I left out any necessary step?
12-20-2008 10:03 AM
Please provide a screenshot illustrating exactly what has not been changed.
12-20-2008 07:16 PM
12-20-2008 11:05 PM
I assume you arrived at this error by clicking on the CiscoWorks desktop icon? If so, the URL pointed to by that shortcut does not change. You will need to create a new URL shortcut. To do this, right-click on the desktop, and select New > Shortcut. Enter the location for the shortcut as http://ciscoworksprod:1741/ . You can change the shortcut icon to the CiscoWorks icon by pointing the icon path to NMSROOT\MDC\etc\ciscoWorks.ico.
12-21-2008 06:05 AM
Hi jclarke,
I have created the shortcut. But it seems like I am still not able to view the login page from the new url. Web browser still prompting "The page cannot be displayed" error.
I tried to start and stop the Daemon manager for several times but problem remained unsolved.
I have attached the running result for hostnamechange.pl script. Please advise. Thanks!
Yi Shyuan
12-21-2008 09:39 AM
Since the URL in the browser is clearly the old hostname, how did you get to this error? If the new shortcut points to the new hostname, and ciscoworksprod is the actual COMPUTERNAME of this server, then you should get a successful connection.
Are you getting the same error when the browser is showing the URL to be http://ciscoworksprod:1741 ?
12-21-2008 10:06 AM
yes, even with the with the new url http://ciscoworkprod:1741
12-21-2008 10:33 AM
Please post the output of the pdshow command.
12-21-2008 07:02 PM
Where can I get that?
12-21-2008 09:59 PM
From a DOS prompt, run the command pdshow, and capture the output.
12-21-2008 11:29 PM
12-21-2008 11:38 PM
According to this, everything is running properly. You should be able to go to http://ciscoworksprod:1741/ on the server itself, and receive the login screen provided that really is the hostname of the server (i.e. in the output of the DOS command "SET" the value of COMPUTERNAME is CISCOWORKSPROD). You can also try connecting to http://IPADDR:1741 where IPADDR is the IP address of the server.
12-21-2008 11:42 PM
I tried using http://IPADDR:1741. It gave me a blank screen immediately aft login. LMS Portal works fine when I tried to change the hostname back to the old one.
12-21-2008 11:46 PM
If the old hostname still works, then you have not properly set the hostname on the server. Please post the output of the DOS SET command, the NMSROOT\lib\classpath\md.properties, and the NMSROOT\MDC\etc\regdaemon.xml.
12-21-2008 11:55 PM
