CW LMS
PSPC Networks
I have a question about CW LMS discovery job, yesterday  I set a job on system to go and fine my devices, but unfortunately it stuck in the system and does not allow me to set any other job, it is about 2 days that this job is there and never like to go out of the system. I start stop the manager deamon and even restart the server for 2 times but nothing changed.
Any one knows how can I remove this job from the server. Please do not advise me to go to the Device Discovery and cancel it, because cancel option even is off!
Michael
AFROJ AHMAD
Hi Michael,
check the status of "CSDiscovery" process  in "pdshow -brief"
try to restart only this process::
pdterm CSDiscovery
and then
pdexec CSDiscovery
now , see if you the job is cleared..
if not share the pdshow -brief output , along with csdiscovery.log and ngdiscovery.log after enabling debugging.
Thanks-
Afroz
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Michael,
pdterm CSDiscovery
and then
pdexec CSDiscovery
Thanks-
Afroz
