CW2000 , Devicemanager
dvanhoyweghen
Community Member
When we select ?add packages? and start the update we see a CCO connection being made but then
with staging Area Contents we get following message:
JRun Servlet Error
com.cisco.nm.dsu.ui.servlet.RepServlet:
java.lang.ClassFormatError: com/cisco/nm/dsu/pkgs/SwitchAddlets/PkgDescr
(Truncated class file)
What kind of problem is this ??
regards
Dirk
7 Replies 7
frankzehrer
Level 8
Level 8
Hi Dirk,
what java version are you using??
open a DOS-Box and post the output of java -version.
Btw. IE7 seems not to be supported!!
Do you have any popup blocker or something like this activated?
Best regards,
Frank
Hi Frank ,
thanks for your response.
the version of Java Plug-in : 1.4.1_02
IE 6 is used
regards
Dirk
Joe Clarke
This looks like a problem with either your current SwitchAddlets package, or the one downloaded from Cisco.com. How much disk space is left for the file system into which CiscoWorks is installed?
Mr Clarke,
Where can I see the current SWitchaddlets package in my CW ?
regards
Dirk
The SwitchAddlets package must appear in two places. The packages must be identical. The two locations are NMSROOT/www/classpath/com/cisco/nm/cvw/devpkgs/SwitchAddlets.zip and NMSROOT/www/classpath/com/cisco/nm/dsu/pkgs/SwitchAddlets.zip.
Mr Clark,
what do You mean about the disk space , is that the total space of the server that is left ???
regards
Dirk
Yes, the disk space on the server.
