CWLMS Archive management problem
ajay-pawar
while saving the back up configuration of device in archive management feature of CWLMS it saves in back directory name in numeric format due to which unable to find particular device so how can we set the back up directory name as a hostname or ip address of deivce pls help.
Joe Clarke
Those directories are not meant for direct human consumption. Instead, use the shadow directory under NMSROOT\files\rme\dcma. This directory stores the latest version of each device's configuration indexed first by device type, then by device name. This directory is meant for direct human access to the latest archived configuration.
But in shadow directory i am not getting backup of all the devices.
Make sure the shadow directory is enabled under RME > Admin > Config Mgmt > Archive Settings, then perform a sync archive on one device whose config is not in the shadow directory. If it is still not created, check the dcmaservice.log for errors.
