Data Discovery filter
tsmarcyes
Level 4
Level 4
Is there any way to set the device discovery so that if it finds two ip addresses that belong to the same switch (more than one vlan int), then it only adds one instance of the switch instead of an instance for every ip add it finds?
Joe Clarke
Assuming Discovery supports the device, it will only ever add one instance of the device to DCR even if the device has multiple IPs. Discovery will attempt to learn all of the IPs from the device by polling the ipAddrTable. It will then determine a unique management IP and hostname for the device. It will be that value that is sent to DCR.
