DCNM-LAN Client Issue
tira li
Hi All,
      Here are my situation:
      1、After upgrading successfully from DCNM 6.1(1b)  to the newest version 6.1(2), I found that the tool "Preferences" of DCNM-LAN client didn't work. When clicking the button or enter "ctrl + I" , it  responded nothing. The upgrade processor was successful, nothing error happened.
      2、After setting the Memory threshold rule(rising 80% and sending email and event, severity was emergency) on LAN-client and binding the N7K, I found that the Event Browser claimed some emergency event about 31% of memory value <70. That is very strange.
      3、How to inactive or increate the timeout of session for logining the DCNM Server Web.
      I will appreciate your advice, thx in advance!
Tira
tira li
can anyone help, thx in advance!
