Debug Copier
egeorgopoulos
Level 3
Level 3
is there any program that copies the debug entries in a text file automatically, without copying and pasting.
thank you in advance.
Jon Marshall
Standard windows Hyperterminal gives you the option to capture the text of a session to a text file.
Under "Transfer"
"Capture text"
Start it, specify a text file to save to and when you are finished
"Transfer"
"Capture text" -> stop
Jon
srimural
Level 4
Level 4
Even you can set the log file in normal telnet and setting the log file.
c\:> telnet
Microsoft Telnet>set logfile
Microsoft Telnet>set logging
This can get you the required out put in a text file.
Thanks and Regards,
Srinath.M
