Default IP address
icommpro1
I have a Cisco 1252 AP Autonomous I just reset to factory defaults.  Unfortunately I do not remember the IP address.  I believe it is on a 10 net but do not remember.  Can someone assist me with this?
Traian Bratescu
Default IP Address Behavior
When you connect a 1250 series access point running Cisco IOS Release 12.4(10b)JA or later software with a default configuration to your LAN, the access point requests an IP address from your DHCP server and, if it does not receive an IP address, continues to send requests indefinitely.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1250/installation/guide/1250HIG_TD-Book-Wrapper/125h_c3.html
Traian
