Deploying a saved configuration to a different switch
brivington
Hello, I am using CiscoWorks LMS 3.2 and I am trying to deploy a configuration from one switch, to a different (but same model) switch. Any assistance would be appreciated.
Thanks.
Joel Monge
You can do this under RME > Config Mgmt > Config Editor > Config Files.  Choose the option that says "External Location", choose the device you wish to deploy the configuration to and then select the configuration you wish to deploy from the shadow directory located under CSCOpx/files/rme/dcma.  You need to actually select the configuration file as "Location" under "External Configuration File" ie. C:/Program Files/CSCOpx/files/rme/dcma/shadow/Switches_and_Hubs/PRIMARY/cr-nms-6506e.cfg.  Then click on Edit and hit Deploy.
Joel Monge
