Deploying Cisco Prime Infrastructure 1.2
terstegen
For the deployment of Cisco Prime Infrastructure 1.2 do I need to have 1 or 2 appliances or vms.  From what I can read version 1.2 is supposed to combine Cisco Prime LMS and NCS into one pane of glass for management so I would assume that I would only need one appliance or VM.
Thanks.
Tyler
Marvin Rhoads
Not completely just yet. PI 1.2 does incorporate some LMS 4.2 functionality but falls short of a complete replacement. So for now if you want all the bells and whistles of LMS 4.2, you still need to build a separate instance of LMS. At least it is included with the PI 1.2 license.
PI 2.0 is supposed to bring more feature parity - we'll see though....
Marvin
Thank you. It assures me that the installation was correct and the OVA deployment is efficient and quick. Are the full versions also availaible as OVA vm.
Thanks again
You're welcome. Please rate the post and mar your question as answered if it indeed is.
Marvin
You also answered my question, but I am not the originator of this post
Terry
