Device in IPM shows in Collector Target list but not in Source list
brianhill88
I'm trying to create a jitter collector between two routers. The device I have configured as the responder (which will be the Target) shows up in both the Source list and Target list. The other device that I have just recently added shows up in the Target list but not the Source list, which is where I need it. How can it be in one list and not the other?
I tried deleting the device and re-adding it but it still does not show up in the Source list.
Joe Clarke
The device needs to be SNMP reachable from the LMS server, and you need to have valid SNMP read-only and read-write credentials entered in DCR for this device. Also, the device needs to be running an image capable of IP SLA source operations. Any image OTHER than IPBASE image will work.
I doubled checked the SNMP and IOS version. They were fine.
It looks like it may have been an OID problem. I deleted the device again and this time when I added it I chose the first OID version instead of the second one listed. The device now shows up in both Source and Target lists under collectors.
