1. Maybe. A trunk port to DFM is a port which connects to another device which is managed by DFM. This could actually be a port in an access state. If the port really is trunking, but DFM is not managing the peer device on the other end of the trunk, then DFM will treat it as an access port.
2. Do not create groups in DFM to do threshold manipulation. Instead, choose one of the customizable interface, port, or device groups, and edit them. Apply the desired ruleset, then adjust the grouping priorities under DFM > Configuration > Polling and Thresholds > Setting Priorities so that your customized group comes before the other system-defined groups. Then apply your changes, and you should be able to see the matched devices. You can then assign specific thresholds for those matched devices.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
