DFM error in device allocation settings screen
Michel Hegeraat
Level 7
Level 7
New install of lms3.2 on windows 2K3
I see this error in the auto allocation settings
Error in getting instance of TreeGenerator class
com.cisco.nm.trx.kdm.utils.DcrGroupSelectorTreeGenerator
Root Cause:com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
The seed devices in DCR get into DFM but remain mostly learning
All the DFM processes appear to be working. Not sure where to start on this one.
In DFMLogServer.log I see this but not sure who tried to bind to what
15/Jan/2010 09:14:50:044 ERROR  ? ?  - Exception in registry server java.net.BindException: Address already in use: JVM_Bind
15/Jan/2010 09:15:20:700 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
I attached dfm logs in CSCOpx\log  and the smarts logs
If anyone has got an idea what is going wrong here please let me know
Cheers,
Michel
15 Replies 15
That's because DHCP is associated with changing IP addresses.
Obviously the address never changes in this setup.
In this case the DNS entry was only possible by registring via DHCP until the sysadmin was back from leave.
If the fault hadn't occured I probably would not have forgotten to make the received address static.
Cheers,
Michel
