DFM instances
janvandek
Can someone explain me why and the meaning of 2 DFMServer instances.  I have installed LMS3.2 with one license and I noticed that 2 DFM instances are running.
My question is also related to use the scripts for bulk manage/unmanage interfaces in DFM. For example, I noticed expPort.log and expPort1.log files (infact, all log files are double because of the 2 instances) Which log file do I to manipulate? Both? The same interfaces/ports are in both log files...
Thx
Jan
Joe Clarke
LMS 3.0 and higher includes two DFM instances (for scalability).  For the bulk management scripts, you may need to modify both files to get all of the devices updated properly.  The entries in the exp*.log will be applied to the DfmServer instance where as those in exp*1.log will be applied to the DfmServer1 instance.
Joe Clarke
