DHCP Binding oid
nadeem saleem
Community Member
Dears;
Kindly i need the OID for the DHCP binding.
Best Regards
Nadeem Saleem
Rollin Kibbe
Hi Nadeem:
I'm sorry, but you're question is a bit vague.  Are you talking about an interface on an IOS device, and the IP address that is assigned to it via DHCP?
Thanks for you replay,
acctually I was configured a DHCP pool in cisco 6509, and i need to check the number of IP's assigned to the clients from this pool?
I hope that it is clear now.
Best Regards
Nadeem
Hi Nadeem:
In a 6509 with the IOS DHCP server configured, there are several objects in the CISCO-IETF-DHCP-SERVER-MIB for the various statistics involved.  Among them are:
                        cDhcpv4CountDiscovers,
                        cDhcpv4CountOffers,
                        cDhcpv4CountRequests,
                        cDhcpv4CountDeclines,
                        cDhcpv4CountAcks,
                        cDhcpv4CountNaks,
                        cDhcpv4CountReleases,
                        cDhcpv4CountInforms,
                        cDhcpv4CountInvalids,
                        cDhcpv4CountDropUnknownClient,
                        cDhcpv4CountDropNotServingSubnet,
                        cDhcpv4ServerSharedNetFreeAddrLowThreshold,
                        cDhcpv4ServerSharedNetFreeAddrHighThreshold,
                        cDhcpv4ServerSharedNetFreeAddresses,
                        cDhcpv4ServerSharedNetReservedAddresses,
                        cDhcpv4ServerSharedNetTotalAddresses
You might want to just try walking ciscoIetfDhcpSrvMIB and see what all comes out and which numbers work for you.
