DHCP failed in WLAN
staceyfanner
A real newbie here - I need some help on understanding why my WLAN's DHCP configuration is failing on the relevant laptops. It seems to be working fine on the PCs so I'm thinking there is some issue with my WAP.
Attached is my .pkt and the config table that I've been using:
Device Name
IPv4 Address
Subnet Mask
Default Gateway
DNS Address
BranchR
Gig0/0/1
192.168.91.1
255.255.255.0
BranchR
Gig0/0/0
DHCP
BranchSrv
192.168.91.2
255.255.255.0
192.168.91.1
127.0.0.1
BranchAP
192.168.91.3
255.255.255.0
192.168.91.1
192.168.91.2
BranchPr
192.168.91.4
255.255.255.0
192.168.91.1
192.168.91.2
PC0
DHCP
PC1
DHCP
LAPTOP1
DHCP
LAPTOP2
DHCP
LAPTOP3
DHCP
Martin L
Yes, issue with my WAP.  WLAN's DHCP side of wireless network is not enabled. Go to Linksys GUI, then  Setup page for Network. Bellow Internet setup there is a Network setup page. click enable DHCP, scroll down to see and click on Save changes; Always save changes for those GUI web based wireless routers.
Regards, ML
**Please Rate All Helpful Responses **
Martin L
Regards, ML
staceyfanner
Thanks so much Martin L - It has worked!
I think I've just got confused as we were also asked to configure a company specific AP which asked for the DHCP to be disabled as per the below
  • SSID: BranchTF
  • Security: WPA2 Personal
  • Encryption:AES
  • Passphrase: BranchTF1!
  • DHCP: Disabled
Is there another setting? For example, on the wireless tab of the GUI
that DHCP: Disabled is wrong; it should be enabled.  probably mistake/ misprint.
Regards, ML
