DHCP keeps "dropping out" or resetting?
Hi.. I have a Cisco 2851 Router and I have DHCP configured... but it keeps " dropping out" or resetting...(Best way to describe it)
ip dhcp conflict logging
ip excluded-address 192.168.0.1 192.168.0.15
ip dhcp excluded-address 192.168.0.30
ip dhcp excluded-address 192.168.0.50
ip dhcp excluded-address 192.168.0.100
ip dhcp excluded-address 192.168.0.101
ip dhcp pool xxxxxxx
network 192.168.0.0 255.255.255.0
default-router 192.168.0.50
netbios-node-type h-node
domain-name xxxxxx
dns-server 71.10.216.1 4.2.2.2 71.10.216.2 1.1.1.1 209.18.47.61
lease 0 7
11 Replies 11
what is drop ?
hi... my DHCP just stops giving out addresses... so I have to log in to the Router and issue the "service dhcp" command.. save the config... reboot and then it works again... for awhile... I am baffled??
show ip dhcp binding
show ip dhcp pool
share both output here
stinger#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address Client-ID/ Lease expiration Type
Hardware address/
User name
192.168.0.16 5cad.76d2.7a9b Jul 25 2022 04:32 PM Automatic
stinger#sh ip dhcp pool
Pool scorpion :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 254
Leased addresses : 1
Pending event : none
1 subnet is currently in the pool :
Current index IP address range Leased addresses
192.168.0.17 192.168.0.1 - 192.168.0.254 1
stinger#
the subnet give 254 (include the lease one)
and there is no exclude IP in show ip dhcp pool !!!
I think it is bug but
ip excluded-address not ip dhcp excluded-address ?
so correct this command
and try add the dhcp exclude range again.
if not solve try add it IP by IP.
under the "pool" I tried ip excluded-address... and it is invalid... I then under the "pool" I tried the ip dhcp excluded-address and it moves it "outside" of the "pool" just like my original config.
I tried to enter the subnet under the "pool" and it was invalid.. also outside the "pool" was invalid
IP dhcp exclude is config in global not under POOL.
after you add
ip dhcp exclude
do
show ip dhcp pool
do you see the exclude line ?
I do small lab for you,
you see the excluded address line appear.
marce1000
                   >.... but it keeps " dropping out" or resetting..
  Provide logs of what you mean by that or else screenshots of the phenomena you are observing.  In general do not use routers or switches for dhcp services but separate appliances , much better, it avoids race conditions when providing network services to clients.
 M.
do you have 'ip subnet-zero' configured ? It should be enabled by default in any newer (>12.x) IOS release, but it might be worth checking anyway...
Is logging enabled on this router? We would be most interested in logging buffered, but would be good to know about each type of logging. If so what severity level is specified? When the issue develops, can you check the logs and see if there are any log messages that might relate to DHCP?
Worst case you might want to run debug for DHCP and monitor the output until the issue occurs.
Rick
