DHCP on syslog server
sergei-bilan
Hi Team,
Whether there is such function what to send from cisco C1111-4P information on DHCP MAC=IP on syslog server which clients receive?
19 Replies 19
what you probably want is an EEM script such as the one below. You can install this script:
switch(config)#
then run it manually by typing:
switch#event manager run IP
The output is still rather unformatted, I am working on the correct output format. This output then can be sent to your Splunk.
event manager applet IP
event none
action 010 cli command "enable"
action 011 set var 0
action 012 cli command "show ip dhcp binding | include Automatic"
action 013 foreach line "$_cli_result"
action 014 regexp "([0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)" "$line" ip
action 015 if $_regexp_result eq "1"
action 016 increment var
action 017 puts "IP/MAC$var $ip"
action 018 end
action 019 end
I will run lab and share with you how we can use debug with logging.
Is it possible to see hostname PC in the logs?
debug ip dhcp server events
glad you got it resolved. I could not really get the regexp to work correctly. Can you post the final script and/or procedure you are using to get the desired output ?
