03-05-2007 08:29 AM
I try to use CNR for assignment of IP address to clients. I'd like to use option 82 - circuit ID and remote ID for IP address allocation - one IP address per one combination of circuit ID and remote ID. Is this possible??
I use the following expression in the client-class lookup ID field of DHCP server setting: (try (concat ((to-string (request option 82 1))(to-string (request option 82 2)))). This string I use for name of client-class. And I made reservation for IP address in the scope. Is this procedure correct? Thanks.
03-09-2007 11:19 AM
Probably your settings will work. You may also get some help from these links:
http://www.cisco.com/warp/public/109/cable_faq_cnr_dhcp.html
03-12-2007 02:07 AM
Thank you for these information. I will try some other script.
Bye
