%DHCPD-4-PING_CONFLICT: DHCP address conflict even with exclude
Kevin18
I am currently working on a HSRP assignment. The active (R1) and standby (R2) router are DHCP Server. But Only R1 get a DHCP conflict even after an exclude command. I think it has something to do with HSRP but I am not sure.
Only after I use the command "clear ip dhcp conflict *", I can solve this problem. But after I close and open the file again, the conflict still exist. Of course I save the progress.
Thank you
I see same subnet in both pool, you must divide subnet
you must split the DHCP pool into two part,
config each part in one HSRP router, otherwise you will see always conflict.
I already split the pool into two part.
R1
R2
The domain-name is the same. Should I change this?
