Difference in Cisco Switch Model Numbers and production dates?
dapaq2
Hello Group,
In the near future I would like to purchase a Cisco switch for use on my home network (rack mount, gigabit, 48 port, POE) But I have run into a problem, there are TONS of Cisco switches listed on eBay and I don't have a clue as to what the Cisco model numbers mean in regard to when they was manufactured/how old each one is or their features and functions. No idea if the item I am looking at is the most current production model or a model that has been discontinued for 20 plus years. Anyone know of a website I can go to that lists ALL the Cisco switch models and tells me what year each was started production and was discontinued and their features/functions.
Thank you,
Doug
9 Replies 9
the below used to apply, that would tell you which year the device was manufactured in.
Cisco Serial Numbers are in the form of LLLYYWWSSSS. The YY and WW values correspond to
the Year and Week of Manufacture. Refer to the table below to determine the manufacture date based on serial number.
(For instance, ABC1234AABB would be 12 for the year and 34 for the week.)
Year Code
01 = 1997 02 = 1998 03 = 1999 04 = 2000
05 = 2001 06 = 2002 07 = 2003 08 = 2004
09 = 2005 10 = 2006 11 = 2007 12 = 2008
13 = 2009 14 = 2010 15 = 2011 16 = 2012
17 = 2013 18 = 2014 19 = 2015 20 = 2016
21 = 2017 22 = 2018 23 = 2019 24 = 2020
25 = 2021 26 = 2022
Week Code
01-05 = January 06-09 = February 10-14 = March 15-18 = April
19-22 = May 23-27 = June 28-31 = July 32-35 = August
36-40 = September 41-44 = October 45-48 = November 49-52 = December
Thank you for the breakdown on serial number manufacturing dates. It may be helpful once I narrow the search down to say less than five different switches to choose from but just starting my search that is going to be time consuming having to check the serial number of each unit I find of interest, there has to be a quicker way to narrow the search quicker. Is there some sort of list or a website that provides a breakdown on Cisco model numbers or model series by years (and features), such as for example:
MODEL NUMBER SERIES = DATES MFG
1200 Series = 2002-2006
1300 Series = 2006-2008
1400 Series = 2008-2009
1500 Series = 2009-2011
2650 Series = 2011-2015
3600 Series = 2015-present
I don't think there is a comprehensive list. What are you looking for exactly, a router, a switch ? Anything not offered on the Cisco website is likely to be end of sale/end of life. The serial number is still your best option when it comes to finding out how old the item actually is.
I am looking for a Cisco SWITCH. Minimum requirements are rack mount, gigabit speed ports, quantity of 48 ports and POE. Are there any specific Cisco switch models you recommend? Preferably I would like a Cisco model that is less than 10 years old...
the 3560 would be an option. They approach the 10 year limit though. What do you need the switch for, production, or practice ?
Cisco - WS-C3560G-48PS-S - Catalyst 3560 48 10/100/1000T PoE + 4 SFP
https://www.tonitrus.com/en/networking/cisco/switch/cisco-catalyst-3560-g-switch/10102666-003-cisco-ws-c3560g-48ps-s-catalyst-3560-48-10/100/1000t-poe-4-sfp-standard-image/?number=10102666-014&gclid=Cj0KCQjw5-WRBhCKARIsAAId9Fn20RMS44tvo0RUzjQMlSU2PzN...
For my own personal home network, but I do NOT want a home consumer model. Are there any other Cisco models you'd recommend? Anyone else have any input/recommendations on Cisco switch models?
 - FYI : https://www.cisco.com/c/en/us/products/switches/switch-selector.html
           https://www.cisco.com/c/en/us/solutions/small-business/selector-tool.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
dapaq2
Update: Just wanted to share with you that I ended up purchasing a new in the box Cisco Switch model number WS-C3560G-48PS-S V09. It came preinstalled with IOS version 12.2.(50)SE5. The serial number on it is "X X X 1 5 4 6 X X X X". The sticker on top of switch states "Manufactured 2 0 1 1 1 1 1 5". (I spaced the digits out for easier reading) If I am reading the "Manufactured label correctly it appear that this was made in 2011, but if I go by the serial number and compare with your break down list it would have been made in November of 2015...
Also looking for a breakdown of Models Released by Year... No Joy...
FYI, the chat above IS working for your serial number - as 15 in the chat denotes 2011.
How's the 3650G working out for you?
How's the 3650G wo
