Different behaviour of EEM, same chassis, same IOS
lmcruzmir
Scenario: 2x7201, both running... c7200p-advipservicesk9-mz.151-4.M6.bin
Code applied to both...
event manager applet foo
event none
action 1.0 cli command "enable"
action 1.1 cli command "terminal exec prompt timestamp"
action 1.2 cli command "sh ip nat statistics | redirect tftp://10.255.255.1/NAT-HITS.$_event_pub_sec"
Result:
Router1...
rt1#sh run | b foo
event none
end
Router2...
rt2#sh run | b foo
event none
action 1.2 cli command "sh ip nat statistics | redirect tftp://10.255.255.1/NAT-HITS."
end
The var "$_event_pub_sec" is not recognized but router2 due  the command "shell processing full".
So, is there any way to make IOS shell compatible with that kind of vars?
Joe Clarke
You can configure this successfully if you disable shell processing full, configure the applet, then re-enable shell processing full.  The variable should stick then.
Joe Clarke
