Diffrence between the configuration file in flash memeory vs Startup configuration file in nvram ?
dolanduck.
Hi @dolanduck.
Executing the copy running-config startup-config command creates a copy of the file hosted in RAM in the file hosted in NVRAM.
5 Replies 5
Leo Laohoo
No difference.
Config file is loaded during boot-up and temporarily stored in the NVRAM.
oh ok so by default when i do write or copy run start it stores it to nvram ? does it store it to both ?
I'm going to throw the answer back at you:  What command is used to save the config (original command and not the "shortcut")?
Hi @dolanduck.
oh OK i understand.
