Disable EEM console logging?
craig pardo
I currently have EEM running some applets, and they're working, but I cannot figure out how to suppress the messages popping up in the console.  I send the output from a cli command to syslog using a watchdog timer.
I can do a "no logging console informational", but that shows up in the config as "no logging console"
event manager applet syslog
  event timer watchdog time 180
  action 1.0 cli command "show ip interface brief"
  action 2.0 syslog priority informational msg "$_cli_result"
Is there a way to hide only the eem syslog traffic from the console?
Joe Clarke
No, you cannot do this other than lowering the logging level on the console.  For example:
logging console 4
