Lms 4.2 interface down alert
eng.malak
I receive email when an interface comes down but because i have a lot of routers with a lot of interfaces i can' tell which one came down , is there any way to include the description under the interface in the email ?
Also can i monitor the existence/not of specific route in the routing table and receive email ?
I appreciate any reply
dpatzold1979
my alerts show the port. for example if you have the event description being sent in the email it looks like this.
.EVENT DESCRIPTION       = LinkDown::Component=PORT-Switchname/1.31
.31 being the port 0/31
so for a router that first section after the router name should be the port.
yes ,i receive the same alert but the case i have like 60 routers and lots of interfaces on every router so interfacse s0/0/0.1 is meaningless for me so i need the alert includes the description configured under the interfaces via CLI
Thanks for your reply
