We are currently using Solarwinds to run Compliance Reports for all our Cisco hardware.
One of the criteria is Disabling reverse telnet on these devices.
Previously I have done this under '
Line-console-0
transport input/transport preferred none
This has worked on other routers and switches, but on a few of our Nexus 5548's I can't get this command to run at all.
Under the line console section, there doesn't appear to be a way (or at least an obvious way) to disable this feature.
I'm sure it's just a syntax change in the CLI, but I'm trying to clear up these reports, does anyone know the commands for this?
