Disabling Unused Ports Automatically With Prime LMS 4.2..
bhcc
Is there a way of doing this?
I can obviously generate a list of "Unused Up" ports from within Reports but is there a way of automatically shutting these down?  My only option currently as far as I can see is shutting them down manually - this will be a lengthy process.
Thanks in advance
Chris McGarrah
This is not a Cisco Prime solution (other than using it to distribute the scripts) but see this thread for using EEM/TCL to automatically disable unused ports:
https://supportforums.cisco.com/message/3928892#3928892
