disabling vty autocommand menu for certain users
jcornell
For routers which are acting as console servers, we've currently configured the following autocommand menu
line vty 0 4
 access-class vty-access in
 exec-timeout 60 0
 authorization exec vtymethod
 logging synchronous
 login authentication vtymethod
 autocommand  menu mgmt
 transport input all
However, this causes issues with management systems which expect just an enable '#' prompt.  Is there a way to configure the router to selectively not run the 'autocommand menu mgmt' based on username (the usernames that are being used by the management stations)?
John
5 Replies 5
Philip D'Ath
I have not tried this, but what about putting the autocommand on the users, not the lines?  For example:
username <username> autocomannd menu mgmt
Then just don't put the autocommand on the users who you want to have "normal" access.
You may need a "aaa authorization" command or similar to allow this.  Not sure.
The issue is that we have around 150+ users who would need need to have that individual command added, but just 5 applications that don't need the menu.  It would be nice if the there was an override for those 5 application users.  And we do use TACACS+ with 'aaa authorization'.
Aha!  If you are using TACACS+ you can probably create a group and a profile, and automatically add it when those 150 users log in.
I thought that might be the answer.  Now I would like to see if there are hints on how do setup this type of profile in Cisco's ACS product.  We already have the AD groups setup and tied to our aaa authorization profile.  We would just need how to pass that autocommand menu option upon console server login.
I'm not sure how to do that.  It might be best to move this thread into the Security/AAA forum.
