Discovery Crashed in LMS 3.0.1
lambay2000
Level 2
Level 2
In LMS 3.0.1 Device dicovery craches @ morning 11:00 everyday,the error it gives is Another instance of discovery is already running.2 instances of discovery are stating at a time 1 craches and 1 get succeeded.
Why it so happening like this??
Altaf
vergeerf
Hi Altaf
You probably have multiple discovery schedules running at the same time. Remove the duplicate schedule. I've seen this several times after installing a Campus Manager patch/update. The patch will add a new (default) schedule.
