Discovery from export
Fabrizio De Carlo
Community Member
is it possible to add devices to DCR automatically from the CLI?
Pratically if I export all the devices using cwcli utility in CSV format, can I import those devices to the inventory with the same format (CSV) .
I want to put this command in the automated Windows task
thank you
Fabrizio
Svetlana Radzevich
We have dcrcli to work with DCR.
In order to import you should use:
dcrcli> exp fn=test ft=csv
In order to export them you should use:
dcrcli>impFile fn=test ft=csv cr=file
In order to have access to dcrcli, you should run from $NMSRoot\bin: dcrcli -u admin.
Svetlana
Svetlana Radzevich
Svetlana
