do basic remote troubleshooting of C891F router using CEEM
j.loduca
Hello
I am trying to get an edge remote router to do basic troubleshooting that gets trigger off Cisco Embedded event manager. I composed a script to do some show commands, traceroutes etc and stuff all results into flash.  When ever the WAN is restored, I can pull the flash and maybe begin to see what broke. I can run the tcl script and it works fine.  Just trying to get Cisco Embedded Event manager to run it. CEEM gets successfully triggered but I believe I have an aaa issue with authorizing my tcl script but not clear on what to do about it.  I ran some debugs below.  what am I doing wrong?
flash:c800-universalk9-mz.SPA.154-3.M3.bin"
no event manager applet test
event manager applet WANDIAG
 event syslog pattern "changed state to down"
 action 1.1 cli command "enable"
 action 1.2 cli command "tclsh WANTEST"
flash file called WANTEST:
set DIAGDATA [open DIAGDATA w]
        set mybuffer [exec "show clock"]
        puts $DIAGDATA $mybuffer
        ios_config "interface FastEthernet0" "no ip access-group Allowed-Nets in"
        set mybuffer [exec "show ip interface brief"]
        set mybuffer [exec "ping 188.240.254.140"]
        set mybuffer [exec "show interface FastEthernet0"]
        set mybuffer [exec "show ip route"]
        set mybuffer [exec "trace ip 188.240.254.140 timeout 2"]
        set mybuffer [exec "show crypto session detail"]
        set mybuffer [exec "show crypto ipsec sa"]
        ios_config "interface FastEthernet0" "ip access-group Allowed-Nets in"
close $DIAGDATA
Jan 26 14:25:21.875: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
Jan 26 14:25:21.875: %HA_EM-6-LOG: WANDIAG : DEBUG(cli_lib) : : CTL : cli_open called.
Jan 26 14:25:21.879: %HA_EM-6-LOG: WANDIAG : DEBUG(cli_lib) : : OUT : DNRSPORTAUST1762WATERS-V>
Jan 26 14:25:21.879: %HA_EM-6-LOG: WANDIAG : DEBUG(cli_lib) : : IN  : DNRSPORTAUST1762WATERS-V>enable
Jan 26 14:25:21.891: %HA_EM-6-LOG: WANDIAG : DEBUG(cli_lib) : : OUT : DNRSPORTAUST1762WATERS-V#
Jan 26 14:25:21.891: %HA_EM-6-LOG: WANDIAG : DEBUG(cli_lib) : : IN  : DNRSPORTAUST1762WATERS-V#tclsh WANTEST
Jan 26 14:25:22.203: %HA_EM-6-LOG: WANDIAG : DEBUG(cli_lib) : : OUT : Authorization request DENIED. You are NOT authorized to execute this command
Jan 26 14:25:22.203: %HA_EM-6-LOG: WANDIAG : DEBUG(cli_lib) : : OUT : DNRSPORTAUST1762WATERS-V#
Jan 26 14:25:22.203: %HA_EM-6-LOG: WANDIAG : DEBUG(cli_lib) : : CTL : cli_close called.
Jan 26 14:25:22.207:
Jan 26 14:25:22.207: tty is now going through its death sequence
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authorization exec default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting send stop-record authentication failure
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
Joe Clarke
You need to configure "event manager session cli user USERNAME" where USERNAME is a AAA user authorized to run all of the CLI commands.
Note: I never recommend combining EEM and Tcl like this.  You should rewrite your tclsh script as an EEM Tcl policy.
