Documentation on advantages on adding switches to Cisco Prime
Fahad Siddiqui
Currently we are running Cisco Prime Infrastructure 2.2. We only use Prime for access point management and monitoring. We use Solarwinds Orion to monitor our switches. I sat in a Cisco Live class 2 years ago on LAN Management with Cisco Prime. Pretty much got out the class that you can do end to end troubleshooting using Prime. Did a bit of googling on this, but couldn't get the answer I was looking for. My question is, what will I get by adding switches to Prime as oppose to keeping them in Orion? I need a few good points to sell them to the business. Are there any documentation on this ?
Thank you
Mark Malone
Main thing is central configuration management and rollout to all devices , when you have a network of 1000 plus cisco routers/switches globally and someone in management decides lets roll out new passwords thats when you want prime , do it once push it out
Compliance for running checks against configs and best practices for specifically cisco devices , extremely flexible with programing options/templates
PSIRT reporting eol/eos/eox and software vulnerability checks per image type for bugs
ACI APIC-EM support /ACS view/IWAN support/ISE/WAAS
Prime 3.0 and above has become very powerful and flexible and integrates now with other csico systems
