does permit udp any eq isakmp = port 500?
hfakoor222
permit udp any eq isakmp eq isakmp
does this equal the port 500 of isakmp,  or does it equal the port isakmp is defined on?
same with this one
permit udp any eq ntp any
is this port 123, or is it the ntp port of the destination router
I am assuming it is port 123
https://datatracker.ietf.org/doc/html/rfc1700
check RFC 1700 for UPD/TCP port for app using in ACL.
for these default APP the UDP/TCP port is known by default and can not change.
https://datatracker.ietf.org/doc/html/rfc2408
