Duplex Mismatch Reporting on gig interfaces
sirbaughmf
The physical discrepancy report is showing a gig-to-gig connections with a duplex mismatch, one is showing half the other full, both are full by default, and unchangeable. Has anyone see this? Is this a bug or is there some other possible error and campus doesn't know how else to report it?
mheusinger
Level 10
Level 10
Which devices are involved?
Are you sure the MIBs are up-to-date?
Martin
Both devices are 3550's and the most current IDU's are installed.
