EASy install problem
Delfino Tiongco
I have Version 12.4(24)T3 on my 3845.
I am trying to install the easy-packet-capture.tar I downloaded from the EASy download site.
I get this error after I run the easy-installer script:
Router#easy-installer tftp://xx.xx.xx.xx/easy-packet-capture.tar flash:/easy
Loading easy-installer.tcl from xx.xx.xx.xx (via GigabitEthernet0/0): !
[OK - 39496 bytes]
ERROR: Failed to import the package configuration: 'couldn't read file
"flash:/easy/easytmpULh79s/pkgconfig": File not found'
Thanks in advance.
Delfino
16 Replies 16
Yeah, that is my internal server.  I have pointed out the problem with the link to someone that can get it fixed.  In the meantime, here is the installer.
Joe,
Thanks for the help.
I get it to work now. One happy ethernet engineer here (o:
Delfino
