EEM applet variables and regex
eekman
Im fiddeling with various EEM applets and feel a bit held back by the lack of documentation. Or maybe my google-searching skills have declined. First: Is there an official documentation of variables somewhere? So far I have pretty much brute-forced my way through whatever I see people use in scripts. This takes forever, especially when doing neighbor-discovery and you have to wait a few minutes for an access point to start and send cdp/lldp packets in order for the event to trigger. If you try to access a variable that is not set the whole applet fails (there is no "try/catch" as far as I know).
Second: Is there documentation of what regex syntax an eem applet can handle? As far as I can tell it is a bit limited, some "common" regex syntax is accepted when configured, the applet runs without failing, but the regex does not match a value in the expected way. Doing things like [0-9]{2} for example does not work the way I expected it to.
Example: $_nd_cdp_platform is "cisco CW9164I-E" after a neighbor discovery event.
# This match
action 0040 regexp "(.*)CW91(.*)" "$_nd_cdp_platform"
# This does not match
action 0040 regexp "(.*)CW91[0-9]{2}(.*)" "$_nd_cdp_platform"
This is all run on Catalyst 9000 devices, running IOSXE 17.12.4. Since it must work on 9200, any TCL solution is out.
11 Replies 11
You want to detect device by cdp?
Give me exact name of device (like it appear in cdp) let me check.
MHM
Detecting devices by CDP/LLDP is one use case, yes. My question though is general, I want to understand EEM script capabilities enough to develop sustainable solutions and not just blindly copy what other people have done that may work but I don't know why.
For the example above with the 9164 AP, CDP output looks like this:
switch#show cdp neighbors gi1/0/2 detail
Device ID: ap1
Entry address(es):
  IP address: 10.1.1.93
Platform: cisco CW9164I-E,  Capabilities: Router Trans-Bridge
Interface: GigabitEthernet1/0/2,  Port ID (outgoing port): GigabitEthernet0
Holdtime : 142 sec
Version :
Cisco AP Software, ap1g6a-k9w8 Version: 17.12.5.41
Copyright (c) 2014-2015 by Cisco Systems, Inc.
advertisement version: 2
Duplex: full
Power drawn: 30.000 Watts
Power request id: 2193, Power management id: 2
Power request levels are:30000 15400 0 0 0
Management address(es):
Total cdp entries displayed : 1
Thanks! But it is 20 years old... but I cant find any info that regex actually has evolved since version 1, so maybe that is srtill accurate. I may also have found the list of variables. In this doc, accurate for the IOSXE version Im running, the different features of various EEM versions is listed (and also that EEM is backwards compatible):
https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/syst-mgmt/b-system-management/m_eem-policy-cli.html
There one can see that CDP was added in EEM version 3.2. The documentation for that is here:
https://www.cisco.com/c/en/us/td/docs/ios/netmgmt/configuration/guide/nm_eem_3-2.html
... and lo and behold, a list of variables!
CW9164I-E
Your regex must match
CW91(any number)(any letter)-(any letter)
^CW91\d+[A-Za-z]-[A-Za-z]$
Note:- way I mention above is how regex understand what you need
Note:- /d+ is same as [0-9]+
MHM
Jens Albrecht
Hello @eekman,
Cisco supports a subset of the classic RegEx and most of the basic stuff should work as expected.
As you noticed some of the modern constructs are not supported:
  • Curly brace quantifiers do not work
    So instead of [0-9]{2} you need to use [0-9][0-9]. Looks ugly but should work.
  • Some advanced constructs like lookahead, non-greedy *? are also not supported.
You can find some EEM example for CDP/LLDP using RegEx here:
https://github.com/kebaldwi/DNAC-TEMPLATES/blob/master/TUTORIALS/EEM.md
HTH!
Just out of curiosity, since I'm probably missing something, but why is TCL out due to 9200?
I've used TCL on some 9200 in the past, and I have a 9200L in my lab (C9200L-48PXG-4X running 17.9.4a) I tested and it works using the ::cisco::eem::event_register_neighbor_discovery trigger, using regex to match C91[0-9][0-9] to match my 9120 AP and creating a log entry.
Please mark helpful answers & solutions
I tried it briefly, but when I run the command to point to the file on flash: I got an error message. GPT said TCL requires 9300 and up and I did not verify that. Considering GPTs accuracy on EEM scripts overall there is a good chance it lied to me.
Switch#debug embedded event manager action cli
Run this debug after add regex as event abd action as anything like puts hello message.
I dont think it issue of regex any more
MHM
For what it's worth, I asked GPT the same, and it told me this as well.
When I challenged it, it said that while guest shells are not supported on 9200, sometimes people may (incorrectly) interpret that as TCL scripts also not being supported, and changed its mind.
Just for reference, this is the snippet I made and tested today
::cisco::eem::event_register_neighbor_discovery interface .* cdp add
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
set platform $arr_einfo(cdp_platform)
set interface $arr_einfo(local_intf_name)
if {[regexp {C91[0-9][0-9]} $platform]} {
    puts "Matched CDP platform: $platform on $interface"
Which gave me this log line:
*Jul 30 10:34:13.199: %HA_EM-6-LOG: myscript.tcl: Matched CDP platform: cisco C9120AXI-E on TenGigabitEthernet1/0/48
And my cdp nei looks like this:
switch#sh cdp nei
Device ID Local Intrfce Holdtme Capability Platform Port ID
AP[...] Ten 1/0/48 169 R T C9120AXI- Gig 0
This DOC was my reference: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/eem/configuration/xe-16-10/eem-xe-16-10-book/eem-event-reg-tcl.html#GUID-C5FC21FE-C9F6-417C-8713-033857204C9F
personally I favor TCL scripts over in-config EEMs for more complex scripts, both because of the flexibility and you have error handling (try/catch).
But this of course depends on the overall team you're in, as others may need to be able to work and troubleshoot this functionality.
Dan Frey
Built in variables are in the show output.
INTERNET#show event manager detector neighbor-discovery detailed
No.  Name                Version   Node        Type
1    neighbor-discovery  01.00     node0/0     RP
	Tcl Configuration Syntax:
		 [tag <tag-val>]
		 interface <interface-pattern>
 		 [cdp {add | update | delete | all}]
		 [lldp {add | update | delete | all}]
		 [link-event {down|goingdown|init|testing|up|reset|admindown|deleted|all}]
		 [line-event {up|down|all}]
		 [queue_priority {normal | low | high | last}]
		 [maxrun <sec.msec>]
		 [ratelimit <sec.msec>]
		 [nice {0 | 1}]
	Tcl event_reqinfo Array Names:
	event_id
	job_id
	event_type
	event_type_string
	event_pub_time
	event_pub_sec
        event_pub_msec
	event_trigger_num
	event_severity
	COMMON VARIABLES:
	notification
	intf_linkstatus
	intf_linestatus
	local_intf_name
	short_local_intf_name
	port_id
	CDP EVENT VARIABLES:
	protocol
	proto_notif
	proto_new_entry
	cdp_entry_name
	cdp_hold_time
	cdp_mgmt_domain
	cdp_platform
	cdp_version
	cdp_capabilities_string
	cdp_capabilities_bits
	cdp_capabilities_bits_[0-31]
	LLDP EVENT VARIABLES:
        protocol
	proto_notif
	proto_new_entry
	lldp_chassis_id
	lldp_system_name
	lldp_system_description
	lldp_ttl
	lldp_port_description
	lldp_system_capabilities_string
	lldp_enabled_capabilities_string
	lldp_system_capabilities_bits
	lldp_enabled_capabilities_bits
	lldp_capabilities_bits
	lldp_capabilities_bit_[0-31]
	Applet Configuration Syntax:
	[ no ] event [tag <tag-val>] neighbor-discovery
		 interface {<interface> | regexp <interface-pattern>}
		 [maxrun <sec.msec>]
	Applet Built-in Environment Variables:
	$_event_id
	$_job_id
	$_event_type
	$_event_type_string
	$_event_pub_time
	$_event_pub_sec
	$_event_pub_msec
	$_event_severity
	COMMON VARIABLES:
	$_nd_notification
	$_nd_intf_linkstatus
	$_nd_intf_linestatus
	$_nd_local_intf_name
	$_nd_short_local_intf_name
	$_nd_port_id
	$_nd_protocol
	$_nd_proto_notif
	$_nd_proto_new_entry
	$_nd_cdp_entry_name
        $_nd_cdp_hold_time
	$_nd_cdp_mgmt_domain
	$_nd_cdp_platform
	$_nd_cdp_version
	$_nd_cdp_capabilities_string
	$_nd_cdp_capabilities_bits
	$_nd_cdp_capabilities_bits_[0-31]
	$_nd_protocol
	$_nd_proto_notif
	$_nd_lldp_chassis_id
	$_nd_lldp_system_name
	$_nd_lldp_system_description
	$_nd_lldp_ttl
	$_nd_lldp_port_description
	$_nd_lldp_system_capabilities_string
	$_nd_lldp_enabled_capabilities_string
	$_nd_lldp_system_capabilities_bits
	$_nd_lldp_enabled_capabilities_bits
	$_nd_lldp_capabilities_bits
	$_nd_lldp_capabilities_bit_[0-31]
