EEM CLI Commands not executed
wmeeren
Hello all,
I have a strange thing happening. I want to run an EEM applet that will remove two BGP network statements when a BGP neighbor goes down. The equipment is an ASR1002, running IOS-XE. There is also AAA using an external Radius server configured on the router.
The equipment is already in production, so it is not easy to test things. First I wait for a syslog message that the neighbor is down. Then I want to execute some CLI commands. I configured the following:
event manager applet TEST-1
 event syslog pattern "%BGP-5-ADJCHANGE: neighbor a.b.c.d vpn vrf XXX Down"
 action 1.0 cli command "enable"
 action 2.0 cli command "config term"
 action 3.0 cli command "router bgp 23456"
 action 4.0 cli command "address-family ipv4"
 action 5.0 cli command "no network a.b.c.d mask 255.255.255.255"
 action 6.0 cli command "no network a.b.c.e mask 255.255.255.255"
When I shut down the LAN interface, the neighbor goes down, the applet is triggered, I see that, but the networks are not removed from the config. Have I forgotten something?
devils_advocate
Level 7
Level 7
If using AAA, the EEM script needs a username as below:
event manager session cli username [USERNAME]
As far as I understand, it doesn't actually do the Authentication part of AAA (hence no password needed) but it does make sure the username has the Authorisation permissions to run the CLI commands.
