EEM delete a file from flash
extremum
Hello ,
I am new with EEM , I want to delete a file from flash with EEM  , how can I do that ?
event manager applet test authorization bypass
Event timer watchdog time 30 maxrun 120
 action 1.0 cli command "enable"
 action 2.0 cli command "delete flash:test.txt"
Router asks ;
GW#delete flash:test.txt
Delete filename [test.txt]?
How can I send "Enter" with EEM  ?
Thanks .
2 Accepted Solutions
M02@rt37
Hello @extremum
Use the file prompt quiet command to disable the IOS confirmation mechanism that asks to confirm a user’s actions.
event timer watchdog time 30 maxrun 120
action 2.0 cli command "configure terminal"
action 3.0 cli command "file prompt quiet"
action 4.0 cli command "end"
action 5.0 cli command "delete flash:test.txt"
action 6.0 cli command "configure terminal"
action 7.0 cli command "no file prompt quiet"
Best regards
Dan Frey
EEM has file management capabilities
 event none
 action 020 file delete bootflash:<filename>
5 Replies 5
M02@rt37
Hello @extremum
Best regards
Hello ,
Tried but it still require to confirm . How do I confirm with EEM ?
quietsh run | i quiet
prompt quiet
file prompt quiet
quiet
quietdele
quietdelete bo
quietdelete bootflash:gw
quietdelete bootflash:test.txt
Delete bootflash:/test.txt? [confirm]
Dan Frey
 event none
Thanks !
Leo Laohoo
action 2.0 cli command "delete /force /recursive flash:test.txt"
