EEM multiple pipes
kchengva1
can EEM scripts run multiple pipes(|)?
I have EEM 3.2 and 4.0 versions, none of them can take multiple pipe...
Thanks.
Ashok Kumar
Below article addresses what you're looking for:-
https://supportforums.cisco.com/document/75956/multiple-pipe-support
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
