EEM Nested Conditional
ling20125
Community Member
Hi all,
  I have an EEM script written using CLI that includes a nested conditional. I have no problem running only one of the conditional. However, if I nest one conditional within the other, it just gives me this "Missing "end" action in conditional block" message. Here is the basic core structure of my script:
foreach RUN A LOOP
  if CONDITION
     BLAH BLAH BLAH
     exit
     break //if the condition in the if block returns true, I want to do something and break out of the entire foreach loop. Do I use them (exit and break) both or just one?
  else
     BLAH BLAH BLAH
     exit
     continue //again, do I need them both or just 'continue'?
  exit //exit foreach loop
  if CONDITION //another IF conditional
     BLAH BLAH BLAH
     exit
end
  If nested conditional is allowed, is my script in the correct syntax?
Angela
Joe Clarke
Nested conditionals are supported.  It's hard to see if there is a problem with your code or a problem with the device as you did not post your actual applet or IOS version.  However, from the pseudo-code above, it does appear you're missing an "end".  Here is a working applet I wrote to illustrate the nested conditional:
event manager applet nct
event none
action 001 set var "5"
action 002 if $var lt 10
action 003  if $var gt 1
action 004   if $var eq 5
action 005    puts "Found it!"
action 006   end
action 007  end
action 008 end
Note how each conditional must be terminated with an associated "end" action.
