EEM not releasing ttys (and I am using end and exit.???)
I have a eem configured to run a few commands, one of which I had to write as a tcl script as I had an issue with the syntax.
Trouble is it is not releasing the ttys so I get the 'no tty lines available, minimum of 2 required by EEM', which is a terrible shame as when this runs it is simply excellent.
ip sla 200018
icmp-echo 193.128.203.18 source-interface FastEthernet0/1
verify-data
owner nSheridan
threshold 2000
frequency 30
history hours-of-statistics-kept 12
ip sla schedule 200018 life forever start-time now
track 200 ip sla 200018
delay down 2 up 30
event manager applet site_unreachable
event track 200 state down maxrun 60
action 1.0 syslog msg "Site: IP SLA failed"
action 1.1 cli command "enable"
action 1.2 cli command "del /force flash:trace.txt"
action 1.3 cli command "tclsh flash:/tracer.tcl"
action 1.4 cli command "show clock | append flash:trace.txt"
action 5.0 cli command "end"
action 6.0 cli command "exit"
router#more flash:tracer.tcl
set output [exec "traceroute ip 1.1.1.1 source FastEthernet 0/1"]
set fd [open "flash:/trace.txt" "w"]
puts $fd $output
close $fd
router#
Anyone got any ideas, I have been banging my head against a brick wall, and it has "started to bleed" to I thought I would post something up
Thanks in advance.
If anyone comes across this check this link out
https://supportforums.cisco.com/docs/DOC-12757#EEM_and_AAA_Command_Authorization
And look at making reference to a specific AAA methods, as you would say if you were making a 'default' for EEM.  This may be useful.
Joe Clarke
It is not recommended to combine EEM applets and tclsh like this.  You can take your applet to http://www.marcuscom.com/convert_applet and convert it to Tcl.  Then insert your tclsh code.  That will be much cleaner.
